Way to avoid this flat sequence?
I have a rather simple vi (L0.vi, attached) that is for an instructional lab.  I want to have it run so that the only way to shut it down is to use the shutdown procedure- no abort button and no window X- to be sure the heater is turned off each time.  To do this, I need to make sure that on completion Labview actually does exit.  The code I have works, but I've spent weeks now editing old cold from my predecessors riddled with flat/stacked sequences that have driven me mad.  Is there no way around it in this case?  I figure I must be doing something wrong here...
Thanks for any tips!
(4,010 Views)
Hi bgalfond,
why not use this error wire to enforce dataflow?
Edit: instead of clearing the error you need to set it according to the help…
(4,009 Views)
Is this what you mean by setting the error?  It does look to be working fine, thanks!
(3,991 Views)
Accepted by topic author bgalfond
Hi bgalfond,
i meant to replace the ClearError by a "set error" code:
(3,978 Views)
That would be a bit more elegant, thank you!
(3,954 Views)
