Wavelet filter with DAQ
Will there any wavelet filter run at realtime with DAQ card with less time cost.
(3,553 Views)
Hi Turbot,
What environment are you programming in?  Also, I just want to be sure I understand your question:  It sounds like you are looking for a wavelet filter in software to filter your data, but not lose real time functionality, is that correct?
Nicholas B, National Instruments
(3,541 Views)
I am using 8.2. If it is realtime will be better, if not also work.
Just want to filter the data, the earlier the better.
(3,512 Views)
Hi Turbot,
You are in luck!  With the LabVIEW Advanced Signal Processing Toolkit, you can perform standard and custom wavelet design and analysis. You can also search our website or the forums for other instances of information on wavelet design and analysis.
Hope that solves your question.  Feel free to post back if you have any other concerns.
(3,494 Views)
