Waveformgraph error?
On some occassions when continuously streaming data to my Waveformgraph, the graph with go white in color with a red X.  What is happening here.  It only happens sometimes even though nothing has changed as far as settings, sampling rate, etc.  I have to restart my program when this happens.  What is the root cause of this error?  Also, if the error does happen, is there a work around to clear it programmatically from my UI or am I stuck with having to restart my program?
Thank you,
D
(3,899 Views)
May u add your code ?
Ermaksan Machine R&D
Electronics Engineer
(3,897 Views)
I am coding it in .NET but I figured I could get an answer faster from this forum, as I've seen this happen before in lab class using LabView.
(3,891 Views)
You might try posting to the Measurement Studio for .Net forum. Here are two discussion threads in this forum about similar issues.
http://forums.ni.com/t5/Measurement-Studio-for-NET/Why-Does-my-Waveform-Graph-Turn-to-a-Big-Red-X/td...
http://forums.ni.com/t5/Measurement-Studio-for-NET/Waveform-Graph-quot-X-quot-Error/m-p/217817/highl...
Aaron Douglass
(3,849 Views)
