Waveform
i've got a problem with appending signals.
i want to append new values to old values, but the "append signals" adds only one waveform.
the other ten waveforms doesn't exist after appending.
wheres the error?
markus
Message 1 of 11
(4,369 Views)
Markus,
Wire the Appended Signals output from the VI to the output terminal of the case structure rather than the A input.
Lynn
Message 2 of 11
(4,353 Views)
it is connected. i doesn't have cleaned up the wire
Message 3 of 11
(4,352 Views)
actually I dont't know what might be going wrong. Please try with the attatched VI. It is a quick proove of concept example. I saved it as a LabVIEW 7.1 vi, if you are still working with 7.0 and cannot open it, just let me know.
How does it look like? Is it working?
regards
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
Message 4 of 11
(4,330 Views)
hello,
if i try the append signal function with one signal it works correct.
the problem is that i want to work with eleven signals.
markus
Message 5 of 11
(4,325 Views)
OK, I agree.
THe append function seems only to work as expected if the Dynamic Data only contains one channel. have a look at the new example; it shows you how you will have to write your code.
regards
Ingo Schumacher
Message 6 of 11
(4,317 Views)
here s my suggestion (LV 7.1)
regards Timo
Message 7 of 11
(4,306 Views)
i attached an example VI.
In this VI you can see that the single grph shows eleven Signals. to this point everythings alright.
when i want to append signalvalues to the end of the single graph (shown in "wrong graph") the result is wrong. there are eleven values in one waveform. and this waveform is appended.
one problem is also to have the time axis and not a axis which shows an index.
markus
Message 8 of 11
(4,284 Views)
Hello Markus,
please also attatch the Demosignals.vi so I can examine your example.
Ingo Schumacher
Message 9 of 11
(4,257 Views)
here is the demosignal.vi
markus
Message 10 of 11
(4,239 Views)
