Waveform refresh monitoring
 Every time the waveform is refreshed, I calculate the parameters such as the effective value of the waveform.How can I implement it?
(851 Views)
Hi Comp,
So you already calculate the values you need!?
What exactly do you want to implement? Where are you stuck?
Mind to attach your VI?
From your question it seems you need to use a loop to read samples and analyse them several times…
(828 Views)
