Waveform measurement
Hello
i need to calculate total number of groups of 1 as shown in attached waveform using labview. The multiple 1-0 transitions represent exhale and continuous 0 shows inhale cycle. I want to calculate respiration rate from this wave. Please suggest ideas on how to do so using labview. Input is in digital form only. I am using LINX for arduino labview interfacing.
(2,515 Views)
@sd2019 wrote:
i need to look at my data figure and think about how I might group periods of time when my signal is not varying (but stays at 0) from periods where it jumps up and down between 0 and 1.  Maybe I should look at the entire series and think about asking if/where the signal "clumps".  Then I'll spend a few minutes/hours with the LabVIEW tutorials -- I should be able to figure this out by myself ...
(2,491 Views)
Hi sd,
to add to Bob's suggestion: maybe you can even improve the DAQ part of your Arduino to not switch rapidly between 0&1 for that exhale part, but stay at 1/TRUE/HIGH.
(Just to provide an idea: in a PLC you would use commands like TON and TOFF for such signals…)
(2,479 Views)
