Waveform graph to file
Hello!
I'm making a program that is supposed to read waveform graph values into a file. When I open the file I only get those random things up. How can I get the same values that the graph is showing into an csv file. values.PNG
(1,357 Views)
You can read that file using the "Read Waveforms from File" VI. If you want a CSV file, you should use "Write Delimited Spreadsheet" with a "," (comma) as the delimiter.
(1,349 Views)
