Waveform graph random integers
This is part of the problem I'm doing, I'm suppose to produce 20 random integers between 0 and 100 and have them on the waveform graph. The way I have it setup I think is that it is running from 0 to 19 times and that it connect to the graph. Is this correct?
Message 1 of 10
(6,286 Views)
If Iwas going to critique your setup, I would say you did not accomplish it. First, you did not plot 20 integers between 0 and 100. You plotted 19 floating point numbers.
Message 2 of 10
(6,284 Views)
Loo is right, if you want integers you should use one of the "Round to ___" vis that are on the Numeric Palette.
Also you should wire 20 to your N input, then it will run 20 times (from 0 to 19).  The way you have it will only run 0 to 18 (19 total numbers).
Message 3 of 10
(6,280 Views)
alright got it, umm am i still plotting floating numbers still =/
Should I initalize an array from 0 to 20 for it to work the way i want?
Message 4 of 10
(6,272 Views)
Instead of a ceiling function I would just convert it to integer. The way you have it setup, 0 is highly unlikely to ever be selected in your list.
Message 5 of 10
(6,268 Views)
like this?
also am I still plotting 20 floating numbers?
Message 6 of 10
(6,263 Views)
That is much better.
I looked through the previous post. You never mentioned what kind of random numbers you want. What you have there is a uniform distribution. Do you want guassian, normal, exponential? If so, you will need to do more research on random number generation.
Message 7 of 10
(6,260 Views)
well random numbers integers just between 0 and 100 and I want to plot the 20 random numbers on the wave form graph 😃
Message 8 of 10
(6,255 Views)
is the setup correct or do i have to add something else?
Message 9 of 10
(6,248 Views)
There are different type of random numbers. What you currently have is a uniform distribution. There ar normal, exponential, etc. types of random numbers. That is the question you should be researching now. You have the basics. Your next step is to determine the rest of the information.
Message 10 of 10
(6,210 Views)
