11-09-2007 01:50 PM
May be you should try using a downloaded version from the NI site, just in case the problem is with your DVD (???)
billings11 a écrit:
Last thing I did was a brand new clean install of the DVD and it doesn't help.
11-09-2007 02:04 PM
I doubt there is anything wrong with the DVD as it didn't give me an error message or anything. But I was trying to evaluate 8.2.1 and 8.5 on the same machine to decide which one (if either) I should upgrade to, and both installs seem all screwy and I can't seem to get them right. When I uninstall 8.5 it really doesn't seem to actually delete many files. The whole directory is still there, but the registry entries are removed. I'm just going to delete the whole NI directory and start over.
11-09-2007 02:52 PM
11-09-2007 03:30 PM
To date I've never manually deleted anything from the NI directory except from the user.lib section. This computer has been through many installs. It has 6.1, 7.1, 8.2, then 8.5, then uninstalled 8.5 and installed 8.21, then reinstalled 8.5, but NI-Motion, NI-DAQmx, and almost all of the toolkits on the re-install of 8,5 went to the 8.21 directory. And I noticed when I uninstalled 8.5 it never removed the labview 8.5 directory and some of its contents. When I reinstalled 8.5, it somehow kept all my user settings (like turning autosave off) like it never deleted labview.ini from the 8.5 directory when it uninstalled. So then I uninstalled again, uninstalled all toolkits and NI motion, NI Daq, etc. Then reinstalled the whole 8.5 install from the DVD with all the device drivers, NI-Motion etc.
So anyway, I can confirm that the only place I see this error so far is the waveform graph plot legend. I can move the graph itself with the arrow keys, but not the legend. Also when I click on the legend instead of putting dotted lines around the whole legend it only puts lines around one of the waveforms. Its very strange but I guess its not a normal part of labview 8.5. If I create a new waveform graph it seems to be fixed. Once I get all the toolkits in the right places (and mass-compile the toolkits in 8.2 to save over the LV5 vi's that are still shipping in the toolkits) I can try opening other apps to see if more waveform graphs have the same problem.
11-09-2007 03:41 PM
11-09-2007 03:42 PM
11-09-2007 03:49 PM
Sorry, no time to edit my message : The right text is bellow
11-12-2007 08:34 AM
