Waveform chart with stacked plots that uses a plot with more than one Y-scale
I am using a Waveform Chart with stacked plots in order to display various channels of data. In my code I configure which plot is linked to which Y-Scale in order to have only 3 stacked plots with multiple channels each. However, I would like to show this particular channel on more than one Staked Plot. This is, I would like to link a certain Plot to more than 1 Y-Scale. Is this possible using any waveform properties, or would I need to create 2 copies of the channel?
I am attaching a picture, which hopefully clarifies what I want to do.
Javier Ruiz - Partner at JKI
jki.net
vipm.io
(3,399 Views)
I cannot think of a waveform property that will allow you to use the same channel on more than 1 of the stacked plots.  I think the best option is to create the number of copies of the channel you will need to display, so you can see a copy in every stacked plot.
Regards!!
Anuar Rojas
Anuar R.
National Instruments México y Latinoamérica
Ingeniería de Aplicaciones
www.ni.com/soporte
(3,376 Views)
Thank you for the answer. That was what I was trying to avoid. I guess there is no way around it.
jki.net
vipm.io
(3,369 Views)
