Waveform chart in a state machine
Hello Everyone,
I have a problem with drawing waveform chart in my state machine.
The situation is as follows: in one of the states ("Frequency set") I set the frequency. Then, in the next state ("Time check"), I wait for some time, and in the following state ("Data Log") I want to read the data and display it in a waveform chart. How can I create such a waveform? Everything else works perfectly, I'm just having difficulties with the chart.
I want the frequency to be shown on X-axis and the result on Y-axis.
Have a good day!
(2,864 Views)
Then you should be using an X-Y Graph.  This will require you to keep all of your points as an array in a shift register.
(2,824 Views)
