Waveform chart LabVIEW 2009
Hi again
After some further testing we've found that if you move the constant outside of the while loop everything works like it should:
This suggest this is more a problem with how the constant is handled together with the dynamic data type inside a loop, not a problem with the Waveform chart.
I'm doing further test and will update the CAR to reflect the findings.
Best Regards
David
Message Edited by Davidek on 11-04-2009 01:02 AM
Message 11 of 12
(766 Views)
Thank you for the update David
Best Regards,
Jose
Message 12 of 12
(749 Views)
