Waveform array to text
Ok, fun for a Friday afternoon!
I have an automated test where I need to produce an excel report that gets saved as a PDF and printed.  There are currently 4 charts that need to go into the report and I have the history data for each chart going to a separate sheet in excel and sheet 1 has the actual report.  I was having issues getting graphs into excel with the report toolkit, so I decided to format them in excel and look at the different sheets for the data.
I could make a VI that would handle each waveform separately, but I wanted to handle them all in one vi.
Problem:
After running the vi (2011 snippet) looking at the all data array indicator (3d)
Page 0 - I only get a time header, the time is wrong but the other data is correct
Page 1 - Same as 0
Page 2 - all the data is ok and I only get the time header
Page 3 - all headers are ok, the time data is bad and the rest of the data is ok
So I am looking for help to get the correct information for each waveform.  I have been playing with this for a day or so and figured I would ask for some help.  I imagine I messed up an index somewhere....
Message 1 of 8
(5,969 Views)
What you are trying to do sounds certainly do-able in LabVIEW, particularly with the RGT.  Could you attach an example Excel file that shows what the data look like?  If you could also make (on the same or another Sheet) an example of the appearance of the corresponding Excel graph, that would save us a lot of potentially wasted time.
Message 2 of 8
(5,948 Views)
There is a vi called Export Waveforms To Spreadsheet File.vi from the Waveform -> Waveform File I/O palette. Have a look at its block diagram, you could copy it to a new vi and remove the write to file part and the Array to Spreadsheet string conversion. You would have a 2D string array output. Use the array functions and the RGT vis to save to Excel in the format that you want.
Ben64
Message 3 of 8
(5,936 Views)
Out of curiosity, if the end report is a PDF why use Excel at all?  There is a good PDF report toolkit (https://decibel.ni.com/content/docs/DOC-10952) that would let you just generate the PDF directly.
Message 4 of 8
(5,922 Views)
Corrected link: https://decibel.ni.com/content/docs/DOC-10952 (final ")" removed)
Message 5 of 8
(5,917 Views)
Here is an example excel file, the data is on sheets 2-5.  Sheet one is the report I am working on with graphs.  One of the graphs has a secondary scale that I was having problems with RGT.  If you look at sheet 5 the headers worked but the time column is wrong.
So I can get the data to excel, the problem is that when I am indexing the waveform arrays I am messing up the headers and time columns.
Message 6 of 8
(5,904 Views)
Ben64
I had no idea that was there.  I will take a look.
Message 7 of 8
(5,899 Views)
I can take a look at that.
I currently use named cells in excel to arrange (setup) test reports.  My IT department freaked out when I installed CutePDF(?) and they said it could be done from excel.  They said free pdf software was evil for some reason.  But if this can all be done within LabVIEW it could work out well.  I just have to figure out how to make reports with the RGT.
Message 8 of 8
(5,881 Views)
