Waveform Graph with log Y axis prints incorrectly
Running Labview 2014.  I have a waveform graph with a log Y axis.  If 0 or negative values are in the data, the graph draws a straight line down off the bottom of the scale.  This is fine, and is what I would expect.  However, if I programmatically print the VI panel, the zero/negative values shoot positive towards +inf.  I'll sanatize the input data, but is this a confirmed bug?
Thanks!
(3,553 Views)
Not in LabVIEW 2011. See VI and printed pdf.
(3,527 Views)
If I run your vi, I get a vertical line from 1 to 0.1 on the print out....
(3,516 Views)
Just confirmed the same incorrect behavior in 2015 on a different machine......
(3,508 Views)
Insert Max-Min with epsilon before array. This will convert negatives to the smallest positive
(3,472 Views)
