Waveform Graph not showing data for more than 1 second data
I am trying to simulate a three-phase signal by adding 3 different sine signals at different phase and further generating third harmonics. The simulation is running for the 3 second and the events are also trigging in the three second as the requirement, but the graph is showing only last one second wave I have tried a lot even by copying graph from other modules but it’s not working. It’s a humble request kindly assist in this matter. Below is the image, and I have also attached the VI file.
(1,387 Views)
Hi Abdullah,
Can you post your code for an order version.
(1,373 Views)
Accepted by topic author Abdullah001
You see only 1 sec worth of data because you configured the Simulate Signal to generate 1-sec data (100k samples at 100kHz = 1 second)
Santhosh
Soliton Technologies
(1,371 Views)
