Waveform Chart
What doesn't work about it? You're going to have to give a little more detail so that we can determine what you're doing wrong.
Message 11 of 15
(1,040 Views)
You did take out the clearing the chart history inside the loop, right?
Message 12 of 15
(1,036 Views)
Yes the clearing is not in the loop but then the chart goes far beyond t=100 and doesn't stop.
I've attached an image of the kind of result I'm looking for. When a graph is used instead of a chart, It just gives lots of linear plots instead of the curve I need. I also only plots from t=0 to 1.
Message 13 of 15
(1,029 Views)
Accepted by topic author ehalpin13
For the waveform graph transpose your array. The chart can't keep going unless you continue giving it more data. Can you post your updated code?
Message 14 of 15
(1,026 Views)
I just transposed the array and it works perfectly!! Thank you so much for helping
Message 15 of 15
(1,019 Views)
