Waveform Chart stop/start on Key Command
Hey all,
I have a VI with a waveform chart and I want to be able to do a couple of things with it.  Currently I have the chart to start when I press the "O" key.  But this is where I get stuck.  I then need the graph to stop (pause) on a key stroke without losing the data.  I also need a keystroke set up to reset the graph to a blank screen.  Any help would be great.
See attached VI.
Message 1 of 9
(4,739 Views)
Here you go.
Never add a function with an indeterminate length of completion in your UI loop.
Message 2 of 9
(4,722 Views)
Thanks for the post and updated VI. I see that you have the clear history as the outcome from pressing "23" which i do need need!
Additionally, How can I program another key to just pause the graph, without clearing the data.  I want to be able to run the graph as long as the user wants and then extract the data.
Message 3 of 9
(4,719 Views)
Currently if you press any Key besides the O or the I key it will pause. Do you need it to be a specific Key?
Message 4 of 9
(4,715 Views)
Yes, I would like it to be a specific key if possible.
Message 5 of 9
(4,713 Views)
Accepted by topic author Marshman
You answered my initial question fully so I will give you the solution.
Furthermore, I want to implement several of these in a tab control - See VI.  It doesn't seem to work. Could you help with that?
Message 7 of 9
(4,704 Views)
Beautiful!! Thanks!
Message 9 of 9
(4,689 Views)
