07-21-2019 12:04 PM - edited 07-21-2019 12:05 PM
I don't understand control and simulation parameters setting. Waveform chart is not not works like a oscilloscope. How can I do?
Solved! Go to Solution.
07-22-2019 01:17 AM
Hi Mustafa,
Yes, correct observation: a chart is not a scope!
(You know there's a "scope mode" for charts? This is taught in beginner courses for LabVIEW…)
How can I do?
What do you want to do?
How is the attached image related to your VI?
07-23-2019 03:11 AM
@GerdW Thanks..
I'm dealing with electronics. I am a beginner for labview and I have not received training.
1Hz signal is displayed properly. 100hz is not displayed properly. Oscilloscopes has a time/div switch. Is there no such setting on the waveform chart?
07-23-2019 03:29 AM
Hi Mustafa,
Did you notice those "Training resources" offered in the header of this LabVIEW board?
Switch off X axis autoscaling and set your own x scale values to see the waveform with more details…
(It's the same with a scope: using the wrong x scale settings will also not show the desired waveform.)
A waveform chart is not a full-featured scope. It's just a chart.
It displays just what you want it to display. Nothing more, nothing less…
(When you want to implement certain features in your VI then you need to implement them!)
