WaveForm Color
I have a plot area that displays several different waveforms in different colors. The problem that I have is that I am colorblind and I can not see Red or Yellow, so I want to change the color of my plots to Green and Blue.
Is there a way to do so consistantly.? meaning...save such settings so that the next time I open and Run my VI, the waveform will come out Green or Blue right away and auomatically  and so I dont have to go and make the changes manually everytime I run the VI.
Thanks.
(2,901 Views)
If you wanted to do it programmatically, there are property nodes.
Right click your graph, go to Create >> Property Node
For the property, select Plot >> Plot Color
Message Edited by Cory K on 03-05-2009 12:55 PM
Cory K
(2,898 Views)
