Watlow f4 controller Ramp rate
Has anyone set the ramp rate on a watlow f4 controller? If so what vi did you use to set it or did you build your own?
(4,932 Views)
I put it in my Set Temperature method.
Jim
(4,913 Views)
Was this a build your own or was it part of the drivers from watlow?
(4,772 Views)
What  I am trying to do is initilize the watlow controller with degrees in C,  change the setpoint in degrees Celsius then close and end
Is this possible with the exisiting Watlow drivers?
(4,770 Views)
@Sr Test Engineer wrote:
[...] Is this possible with the exisiting Watlow drivers?
Yes.  What have you tried that isn't working?
I wrote the snippet (above) using the Watlow drivers; take a look at the examples that get installed with them.  I'm having trouble with the Example Finder right now, but my snippet shows the steps I'd use.
Jim
(4,750 Views)
