Waterfall plot Sound and Vibration assistant
I'm trying to create a waterfall plot with the Sound and Vibration Assistant. I have several *.lvm files with power spectrum data from several vibration signals taken at different speeds (rpm). So, the problem comes when I try to add more than 1 signal to the waterfall plot. The signals don't appear on the display.
How can I plot the different Power Spectrum signals at different positions in the Z axis (i.e. 180 rpm, 360 rpm, 540 rpm...)
Find here my project file and 3 data files.
Thanks in advance!!
Adrian.
(3,008 Views)
Hi Adrian,
     SignalExpress allows you to represent the results of an order domain analysis (Analysis>>Order Domain Measurements>>Spectral Map) on a Waterfall Plot but I don't think you will be able to represent the data of several *.lvm files on this type of graph.
David Oña
(2,953 Views)
