Warning 1950678971 when reading shared variable from TestStand
At the moment I'm programming a new testbench-application.
I use a cRIO in FPGAMode, RT-Component and a PC GUI. These components are part of a LabVIEW project.
With TestStand I develop some testsequences. In TestStand I do not refer to the project. I only define a VI path.
When I execute VI's i TestStand I see very often the Warning 1950678971 if a shared variable from rt-library has to be read. LabVIEW Help says that the error code is undefined.
The rt-library is deployed to network and in th RT-VI's all shared variables are set to target relative.
Does someone know what th warning means and why it is only if I execute VI's with TestStand?
Message 1 of 1
(1,168 Views)
