Want to update a blob database field in DB2.
I am attempting to transfer a jpg image contained in a SQL server database to a blob field in a DB2 database. I am able to read the image data from the SQL server and I currently have the variant data converted to a string. Now I need to place this jpg's string data into the DB2 blob. How do I do this? Should I be converting the jpg image to a string?
Note: All connections to the databases are through ODBC.
Message 1 of 8
(7,981 Views)
you should convert the jpg file to a string and then change the string throug labview
There are 10 kind of persons. Those who understand binaries and the others.
Message 2 of 8
(7,974 Views)
Hello MCP,
As I stated in my original post, I have already converted the jpg file to a string. What do you mean by "and then change the string throug labview"? How can I now update the blob field in db2 with the string data which is the content of the jpg image?
thanks
Message 3 of 8
(7,967 Views)
But String only allow you 255 length.
Image convert to string will longer than 255 length. that's still a problem
http://www.vitst.com
Virry Test & Control
LabVIEW Certified Developer
Message 4 of 8
(7,881 Views)
hi there
Qia.sky is right. you have to use an appropiate datatype for the field. e.g. in MS Access you use the "Memo" datatype. to write to a database field see attachment.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 5 of 8
(7,875 Views)
chrisger
your way is good.
maybe we could use update method to finish the job.We may don't use string or memo, just treat it like binary format.then write or update it directly into database using SQL like this UPDATE Table SET Data=? WHERE Name=XXX;
But I still have a question
How to update two data of database, for example, there data1 and data2 need to be update
Message 6 of 8
(7,871 Views)
reference post
http://forums.ni.com/ni/board/message?board.id=170&message.id=142184&requireLogin=False
Message 7 of 8
(7,868 Views)
you can use the update(fields[], values[]) method for several fields in one single recordset like shown in the atttachment, but this may cause some overhead because of the variant datatype and the large amount of data. if you use the first vi i posted you have to call the update() method before you change the recordset.
i don't like the SQL-statements that much because sometimes the error messages are quite generic, though the performance seems to be better.
Best regards
chris
Message 8 of 8
(7,862 Views)
