11-26-2007 11:07 AM
11-26-2007 11:31 AM
11-26-2007 01:58 PM
11-26-2007 02:46 PM
Have you checked the switch to make sure that the PC that is offline still connected to the switch (logically)? Some of the PC will not power the NIC connection. This in turn some switches will then disconnect the network connection within the switch or drop the ip address in the table. When this happens, a packet being sent is dropped within the switch. The switch no longer no where to send the package.
You can check this by (not a sure thing) pinging the ip address and see if it comes back as unreachable.
11-26-2007 04:15 PM
11-27-2007 01:53 AM
11-27-2007 03:11 AM
11-27-2007 07:38 AM
11-28-2007 11:43 AM
03-10-2008 07:29 AM
I observed the same problem. Solution: use the broadcast address of your local network instead of the computer IP (in your code 192.168.126.255 instead of 192.168.126.44).
Matthias
