Wait (ms) Function and Cicles
Hi, I want to give a wait to my VI (it could be 1 second same as 1h or more). I was using the wait function but what I want to know is if it is possible to set a break  so that the user can interrupt the VI before the wait function has finished.
In case it is not possible should I replace it with a for/while cicle? If yes, what is the duration of each iteration of a for/while cicle without any element in its inside?
Thank you guys
(3,335 Views)
Accepted by topic author inuyasha84
No, you cannot abort a Wait (ms). You can abort a Elapsed Time function.
It's sillyto ask how much time a loop takes with nothing in it. You can't have a loop wait for x amount of time without code inside the loop.
(3,330 Views)
Yea I suppose that was silly a thing like that with the for/while cicle but I need to set a break.
About the Elapsed time function how can I stop it?
Thank you for your help
(3,325 Views)
It's inside a loop. Don't you know how to stop a loop? Read the help. The Time Has Elapsed output or a Boolean control will stop the loop.
(3,319 Views)
mmm I saw the example and read the help. I think I should use the time delay instead since I want that the user set the time to wait.Is it correct?
EDIT: no you were right. I read better the help.
Thank you for the help now it is clear 🙂
(3,314 Views)
No, no, no.
You can set the time for the Elapsed Time function in the exact same manner as the Delay or Wait (ms). As I already said, you cannot abort the Wait (ms). If you didn't care about aborting a long wait, why did you ask the question in the first place?
This is trivial. Place an Elapsed Time function in a loop with a stop button. Run the VI. Whatch how you can stop the loop at any time. Create an indicator for the Time Has Elapsed output. Whatch it.
(3,309 Views)
yep I edited the message. at the end I did the VI as you write in your last message 🙂
Thank you
(3,307 Views)
