Wait in While loop
Hi
I want my while loop to excute according to the time constant I set in an array, but it won't follow exactly.
For example, I set the time as 1000,1000,3000,3000...: but it's more like 1000,1000,1000,3000....sometimes. but sometimes seems correct...
What's Wrong?
Thanks in advance
帖子被seafood在 05-04-2009 04:44 AM
时编辑过了
帖子被seafood在 05-04-2009 04:46 AM
时编辑过了
帖子被seafood在 05-04-2009 04:47 AM
时编辑过了
(4,247 Views)
Accepted by topic author seafood
Hi seafood,
use the "wait" function instead of the "wait until ...". Is your vi on a RT target? If the loop runs more, then available elements in your array, then you'll get 0 as wait time.
Mike
Message Edited by MikeS81 on 05-04-2009 11:50 AM
(4,240 Views)
Thanks Mike, It works
Now I wonder how accurate this 'wait' could be? in micro seconds region or even smaller?
(4,227 Views)
Hi seafood,
the help says you get a milliseconds value. If you need it more exact, then you should think about a RT target.
Mike
(4,216 Views)
Bingo! If you use a RT target, you can get a subtle accuracy!
(4,183 Views)
