WIN CE error
       I have WIN CE 5.0 i have installed NI TPC Server Managerin WIN CE but the application is not working since labview runtime is not installed. I tried to install labview 11 runtime but not working. Please tell me how to proceed further so that i can isntall run time engineon WIN CE.
(3,574 Views)
AFAIK there is no runtime engine for Windows CE. And the Touch Panel Module only supports Windows XP Embedded and Windows 7 embedded and only for x86 architecture. Windows CE is a very different beast to that. First it is in most cases NOT x86 CPU based, and it only supports a subset of the Win32 API that the standard LabVIEW runtime environment calls into.
The only support for Windows CE from LabVIEW was with the LabVIEW for Windows Mobile Module. But that has been discontinued since LabVIEW 2012 without any replacement, since any Windows CE version can be considered obselete. Even Microsoft stopped support for all of them last year.
Rolf Kalbermatter  My Blog
(3,556 Views)
Thank you for the reply. If i want to run my Labview program on WiN ce what i shld do. I have 2011 labview but theproblem is that i cannot connect to win ce becos its  a third party not NI TPC. What are the best solutions now?
(3,549 Views)
I think you need to talk with NI if they will still sell the LabVIEW 2011 Windows Mobile Toolkit to you. It's officially discontinued and you will be unlikely to get technical support on it now. The cross compiling from LabVIEW to Windows CE was also not trivial and had still several troubles when they stopped the development of that module. So you really need to think hard if you want to head down into this direction. I wouldn't!
(3,529 Views)
