WHY LOCK SYMBOL ON VI ICON
hi,
i would like to know why my project files (*.lvprj and *.vi ) is displaying a lock symbols on it icons?
icons snapshots are attached.
thanks
phani
phani srikanth
(4,765 Views)
Do you use source code control?
(4,711 Views)
No. i am developing labview application in a pxi. It is not connected to network at all
phani srikanth
(4,686 Views)
Where do you see the lock symbol? On windows explorer or LabVIEW project explorer? If it is in Windows explorer check whether the folder where the VI resides is shared. This generally happens lets say your PC has 2 different user access and from one user you are sharing the Folder/file, so for the other user it will appear to be locked which actually shared by the other user on the same PC. Or in other case it may be a read only folder/file.
(4,646 Views)
Typically it happens if you have 2 projects open with some common VI's, in which case they'll be locked. Or you have some VI running, locking code.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,621 Views)
