Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Voltage on graph twice that of input
Hi
The input voltage source is showing twice the amplitude on my graph.
Hardware
PCI-6040 with SCB68
Input
500Hz 0-2V sine wave
When I connect the waveform to any of the analog inputs, a 2V input signal shows up as 4.  I have tried my own program, an example from the help, and Ni-Max all which shows the same thing.  I have it set up as a differential input (the other options show nonsense)
Is this normal behavior?  How do I correct this?  I could use scaling but I didn't want to do this until I knew it wasn't something else I was doing wrong or missed.  Shouldn't the AD show 1V for a 1V input?  When I run the calibration in Ni-Max, the input reading is very close to the signal 2V shows 2.035V as an example.  Additional when I input 8V sine, it only reads 6V.
Aside: I also tried a DC voltage, both from a power supply and a battery.  Both show an output of 10 on a graph.  How do I set up ni-max to measure a straight DC voltage?
Thanks for your help
(1,751 Views)
It sounds kind of like you are mixing up Vrms and Vpp, and to add confusion, you are also doing differential input...
I would recommend, instead of just guessing at what the input is supposed to be - e.g., "the other options show nonsense", you should revisit exactly what you are trying to do, and how you are supposed to do it.
Bill
CLD
(Mid-Level minion.)
(1,746 Views)
It is impossible to solve your problem from a vague description. Can you show us some code? What is dy of the y scale? Could the sine wave be -2 to 2V? What's the frequency?
(1,741 Views)
Hi
Using NI-Max (test panel or create task)
The input signal is 0 to 2Vpp at 500Hz.  The output on the graph is 0 to 4Vpp.
The calibration tab under Voltage Input Setup for creating a task using Ni-Max shows the board reading 2V for a 2V input.
The input signal is generated with a function generator.   Not using a differential input shows nonsense because the grounds of the two systems are not the same.
I used NI-Max under the test panels tab and create task so no code to show.
pete
(1,708 Views)
Hi
I used Ni-Max (both under test panel and create task) so I have no code for you.
The input is 500Hz 0-2V, for clarification 0-2Vpp.  The output shows 0-4Vpp 500Hz.  I used a function generator to create the signal, the signal was verified to be  0-2Vpp (using a scope)
I haven't put in any scaling for the x or y axis.
The board seems to be reading the input correctly  (seen under the calibration tab of Voltage Input Setup in Ni-Max)  but doesn't display it correctly.
pete
(1,707 Views)
