My testing shows that it is MessageBox font, not icon font.
I would avoid this, because it is global throughout Windows. If a user can't stand seeing the font you specified, then your application breaks again. If you install it on another machine 1 year from now, you have to remeber what you had to do.
I would suggest doing what I suggested the first time - use a Windows font for your controls, indicators, and labels that is available on both platforms, or change the application font in LabVIEW and your application.
In LabVIEW, the fonts can be changed in Tools->Options. This will add an INI file entry for the change. I changed mine to Times New Roman and had the follwoing entry:
appFont="Times New Roman" 13
so, you can specify the font and size to use for Application font and not have to change the Windows settings of every PC you put your program on.
You can add the same entry to your EXE's INI file. If your EXE is named
MyApp.exe, then you need to have a
MyApp.ini. If you happen to already have one, then add the following lines of code. If you don't, create the file and add the follwoing lines:
MyApp]
appFont="
MyFont"
MyFontSizeWhere
MyApp is the name of your EXE without the .exe,
MyFont is the name of the font you wish to use, and
MyFontSize is the size of the font you wish to use.
