Vision Example Vi's Missing
Hello Everyone...
I have to do some kind of measurement and calibration using  LabVIEW Vision that is not supposed to be complicated but I'm not getting it. Its very similar to the example nonlinear calibration:
http://zone.ni.com/devzone/cda/epd/p/id/5719
The problem is that the example vi file is missing in the folder ...\LabVIEW 2011\examples\Vision\2. Functions\Calibration. In fact many others Examples Vis  are missing giving me the message:
"That file could not be found or opened. You may need reinstall your examples."
I don't know how to reinstall the examples, but I have reinstalled the LabVIEW and the problem stand still. I tried to get from another version of labview and the Vi is missing too. Someone can help me to obtain the missing files especially the nonlinear calibration.vi?
(3,582 Views)
NI-Vision is an add-on that you must purchase. Did you?
(3,581 Views)
Yes, I have the LabView and Vision Development 2010/2011. I think that I have seen the and used these examples on Labview 8.6 that I used to work. I know that they work perfectly.
Thanks for answering
(3,576 Views)
Here is the Vision Function Vi's at folder examples. These Examples Vi's were from LabView 2011, so it will only open in your LV 2011 and only if you have the NI Vision installed.
I hope this can help you.
(3,555 Views)
Thanks Rick,
But the Vi that I need is not present in the zipped folder you attach. According to National Instruments "This example requires LabVIEW and is included with the Vision Development Module. Download the LabVIEW Evaluation and the Vision Development Module Evaluation to try this example."
I have both installed and working but some Vi's are missing and seems like they are missing to you too. Examples like nonlinear calibration example.vi and perspective calibration example.vi are missing. If you attach them it will help for now but I would prefer the solution for the problem...How I reinstall the examples like NI said to do? I tried to install in another computer but is still missing...
(3,539 Views)
