Visa Serial interface problem
Hi Zahran,
ok, my fault: because of that big image I overlooked the attachment.
But anyway: I guess you are able to reproduce those two simple steps! 😄
Message 11 of 14
(916 Views)
Yes man for sure I tried it but not working. I also used the termination character "\n" to help but still I have the same error massage!  you can find the attached file Smiley Happy for the modified code
Message 12 of 14
(913 Views)
Hi Zahran,
What is "not working"?
What is the return count?
What is the received string?
Which error do you get?
In the attached VI you are using the LF (aka \n aka LineFeed) as TermChar as it is the default value of VISASerialPortConfig! According to your first post that should do it: your data message ends with "\r\n"…
(I hope you are talking about those control codes aka CR/LF aka hex values 0D/0A…)
Message 13 of 14
(910 Views)
I can't believe I missed the attached file on your first post.  Ugh.  My apologies!
Bill
CLD
(Mid-Level minion.)
Message 14 of 14
(897 Views)
