Virtual Labview instrument in Multisim - DLL?
I am using LabView 8.5 and I followed all the steps given in "How to Create a LabVIEW Based Virtual Instrument for NI Multisim" tutorial. After creating the instrument and copying it into the specified folder, I am supposed to find the new instrument in Multisim (Simulate > Instruments > Labview). However, it is not listed there. When I go to the folder \lvinstruments, I see that all the other instruments that are present (also seen in the LabView instruments list in Multisim) have a separate DLL file. In the tutorial there is nothing about creating a dll file. If it is required, how do I create one?
Thanks!
(3,025 Views)
Hello srbadri,
if you followed the given steps in the following file, the implementation of  your "LabVIEW Based Virtual Instrument" should work as expected please check again step by step the given guidance.
http://zone.ni.com/devzone/cda/tut/p/id/5635
Regards, Jan
Jan Kniewasser | Applications Engineer | Tel.: +49 89 7413130 | Fax: +49 89 7146035
(3,001 Views)
