Viewing Data in real-time with excel
Currently I am using labview to output the data into an excel spreadsheet.  Is there someway that I can have the data output with the spreadsheet open so I can see the results as the data is returned?  Currently I am typically doing experiments with sample intervals of 5 seconds and a total time of 300 seconds.
Any Ideas, or am I missing something fairly obvious?  I am rather new to LabView.
(2,798 Views)
Are you using the report generation toolkit?  This is fairly easy but the answer depends on how you're writing to excel.
Can you post some code so we can take a look?  Or explain more of what you've tried thus far?
(2,793 Views)
I am using the box diagrams, not actual code, with labview 8.0.  I could post the file on the web but I do not know how to get a code representation of it.  Like I said I'm new to labview and have only used the tutorials and How-To book to make the program.
Chris
(2,766 Views)
The BLOCK diagram is the actual code. Exactly what functions are you using to write to Excel?
(2,758 Views)
www.andrew.cmu.edu/user/cdboyd/labview.vi
is the file, I'm not on a PC with labview at the moment but Im headed into the lab soon and will post some later.
(2,750 Views)
