Vibration Output using SCC-68...
Hi, I have SCC-68 with DAQ-M Series. I am working on force feedback concept and I need to get vibration output from DAQ. I am giving 3 inputs to the system. For testing purpose, i have connected the buzzer in ao0.. Even after simulating 3 signals using daq assist, i am not able to get the output.. how do i rectify it?
Also i need to connect multiple vibration motors in future. Is it possible to do that using SCC-68?
I request you to kindly help on this..
(3,341 Views)
The scc-68 is just a dumb terminal block. What is the actual DAQ device? How have you programmed it (attach VI or snippet)? How have you wired it?
(3,333 Views)
Thanks for the reply sir. We have NI-PXI-6259, 4496 both M-Series. My three inputs are,
  1. Steering angle              -   DAQ assistant (Potentiometer- Using PXI 6259)
  2. Aligning Moment          -   Simulate signal
  3. Vertical Displacement -   DAQ assistant 2 (Accelerometer- Using PXI 4496)
I need to make a motor to run after getting 3 inputs. As of now I have connected a buzzer for testing purpose. I am giving an external 5V power supply.
I am completely new to this. Please, do the needful.
(3,300 Views)
