Vestigial fields when exporting shared variables
Is this a bug? I have a network-published shared variable that used to have aliasing enabled. After I cleared the "Bind to:" field and disabled aliasing, I exported its library into CSV mode. However, it still contained the columns (among others):
Network:ProjectBinding = TRUE
Network:ProjectPath = <old variable that it was bound to>
The extra columns messed up my CSV parser. The only way I could find to prevent their appearance was to delete all the variables that used to have project binding, and re-create them 😞
Certified LabVIEW Developer
(3,114 Views)
Forgot to add: I'm using LabVIEW 2012
(3,102 Views)
JKSH,
I was able to reproduce the same issue here.  I'll look into this a little more and see if this may in fact be a bug.
James K.
(3,079 Views)
Hi James,
Thanks for looking into this. Any updates?
(3,048 Views)
