Very strange behaviour of table values and event case
Hi all
i'm becoming crazy on my .vi
i want to change the second col values on click from yes to no and from no to yes simply by a click.
The problem is that this changing happens after some clicks on an old position.
Try to click on some "no" on the file that is attached.
Thanks a lot!
Dario
http://www.sd-studio.it - web design agency
(2,644 Views)
The issue took me a sec to understand but here it is.  You are trying to change the value during the mouse up event.  And you do... however you have just selected that cell in the table.  So LabVIEW is waiting for the user to change the value, and in this case ignoring your change.  All you need to do is add a property node to the end of that sequence that is Key Focus and set it to false
(2,638 Views)
hi evan
you're right
now i've moved the writing into timeout (so out of mouse up event) and added the key focus node and now it is working properly!
tnx a lot
(2,632 Views)
