Very easy translation of front panels and RTMs (without Export/Import VI Strings)
I have developed a "translate.vi", that makes it very easy to translate all
front panel strings and Run Time Menus (RTM) of your VIs in three steps:
1. Place the "translate.vi" at the beginning of the VI which strings you want
to translate (main VI) and start the main VI.
2. In the directory of your main VI a translation file "strings.txt" was
created, that contains a column of front panel strings of your main VI.
Add a new column for each new language to the translation file.
(e.g. with EXCEL).
3. Select the language index of the translation VI according to the desired
language and start the main VI again. That's it!
This works also at run-time and even after modifications
of your VI!
The reason why I have developed this VI is that the Export VI Strings and
Import VI Strings method of LabVIEW has many disadvantages:
- If you modify the VI, importing a previously exported and translated text file
results in errors.
- The exported text file has a structure close to XML. If you want to give it a
translator, you would need a parser that would allow you to extract only
the translatable strings.
- It is not possible to change the strings at runtime, because the you can
not import the textfile if the VI is running.
- Each VI of your application has its own textfile. If same strings appear in
many VIs (like "cancel" of a cancel button), you have to translate them in
each textfile.
- Run Time Menu (RTM) items are not included in the exported textfile.
I will send a tutorial (PDF file, 2 pages), documentation (PDF file, 3 pages)
and a demo to everybody who is interested.
Please send me a short email.
Robert Nell
Message 1 of 11
(5,270 Views)
Your program sounds really cool. Are you using VI server to get the contol names and reset them?
You can submit your code to NI to be put on their example database (if you are interested) at:
http://zone.ni.com/devzone/explprog.nsf/NIDNsubmit
Jeremy
Message 2 of 11
(5,267 Views)
Version 1.1 of my translate.vi with new features is available now.
If you are interested, please send an email to nell@rofa.at
Message 3 of 11
(5,267 Views)
Hi Rober Nell,
can you please send me the tutorial and the demo of your programm. Becaus I haven't found a solution for my problem yet. I have to translate my program(including several sub vi's)into different languages.
I hope your software will help me.
Thanks for your help and have a nice weekend.
Message 4 of 11
(5,267 Views)
Hello Robert:
I would like to try out your vi for translation. My e-mail is mspath@dynisco.com
Message 5 of 11
(5,267 Views)
Hi Robert,
I would appreciate if you could send me your soloution to the multi-lanuguage interface problem - do u also have a solution for labview system messages other than the 4 standard languages?
Gerhard
Message 6 of 11
(5,267 Views)
If you have LV 6.1 or 7 the system error messages are located in a subfolder named errors of the shared\LabVIEW Run-time\ folder. You can change the textfiles, they are very simple XML. I think there is a subfolder for each runtime language but the filenames are the same.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 7 of 11
(5,267 Views)
Hi Robert,
I'm very interresting in your prg, but nothing appends when I use It : I'm using LabView V7.0 and I think it's the reason why.
Do you have a version of your library which work with LV7.0 ???
Please Help...
Eddy
Eddy DUCHENE
12 F Chemin de Boutary
69300 CALUIRE ET CUIRE
educhene@laposte.net
Message 8 of 11
(5,267 Views)
HI i'm very intersting in your translat.vi can you send me ?
thank you very much
Message 9 of 11
(4,733 Views)
Can you please send me the PDF documents and VIs for easy translation.
naganathas@yahoo.co.in
Thanking you
Naganatha Subramanian
CLAD, Bangalore
Message 10 of 11
(4,056 Views)
