Vertically Center Displayed Number in Numeric Control
Dear All,
I'd like to use a simple numeric control (or indicator) with a height that can be adjusted. The only available option is in the Classic palette -> Classic Numeric -> Simple Numeric. This creates a nice, simple, numeric control with adjustable height. However, if you make the control taller (for example, right click on the control and chose properties, height = 24, so the height of the control is two times the default front panel grid size) the number displayed in the control does not stay centered vertically.
Here is the control with default size (default height  = 19):
Here is the same control with the height set to 24:
I would like to make the height 24px while keeping the number centered vertically. Has anyone had a similar question and found a solution? I would be happy for any advice.
Best,
Ed
Message 1 of 11
(5,373 Views)
Hi edward,
change fontsize to ~20 to have the number vertically centered… 😄
Other workarounds
- use a picture indicator and "draw" your text at the exact position you want to have…
- use a transparent indicator showing your number and place it over a graphics/image of the border and background…
Message 2 of 11
(5,359 Views)
Attached.
George Zou
Message 3 of 11
(5,324 Views)
Hi George,
Thanks for sending the control. When I open the attached control in LabView 2014 I see the height as 26. I also can't change the height of the control.
Best,
Ed
Message 4 of 11
(5,274 Views)
That must be the font you use.  If you use app./system font, what OS are you using?
For system numeric control, you can NOT change the height in edit mode.
It automatically adjust to the font size (if > 24).
George Zou
Message 5 of 11
(5,269 Views)
I changed the font to Segoe UI 13pt
George Zou
Message 6 of 11
(5,264 Views)
Accepted by topic author otheredward
Customize the control this way.
  • Drop a Numeric on a BD
  • Create a P-Node Numeric Text.size.Height
  • Create a control for that value
  • run the vi
  • Select the Control and Create a type def
  • Edit the type def By:
  • Make the part Numeric Text Transparent
  • Move it down until text is centered Adjust height
  • Select the Frame and set its background White
  • Adjust Height and Top of Inc/Dec arrows
  • Let radix resize itself
Add an Icon, save and apply changes. Bingo!
Silly workaround but if you need it you need it
"Should be" isn't "Is" -Jay
Message 7 of 11
(5,253 Views)
When you change the background color, there will be no difference between control and indicator.
George Zou
Message 8 of 11
(5,250 Views)
TRUE but, in a where used case, you can "disconnect from typedef" and recolor the frame at edit time.  I mentioned it was a flawed work-around.  No other options would be possible even with an X-Control since frame BG Color has no p-node support. (sad)
Message 9 of 11
(5,241 Views)
Why not simply skip those change color steps?
Works fine without those steps for system control.
George Zou
Message 10 of 11
(5,232 Views)
