Vertical string concatination
I have a simple question, but I cannot find the answer...
I have three strings: string1, string2, and string3.
I used the concatinate strings function to obtain a concatinated string that reads:
string1string2string3
How do I get this to read:
string1
string2
string3
I have tried to insert newline characters and the like, but that has not worked.
Thanks.
(2,705 Views)
I found what I was looking for.  I changed the display mode of the string constants from 'Normal' to '\Codes Display', and the output string now reads the way I want.
(2,699 Views)
I am assuming you are referring to the fact that you had a string constant and you entered the text "\n" in it while it was in Normal display mode. As you discovered, that simple means a string that has 2 characters: the character "\" and the character "n". Why don't you just use the New Line and End of Line constants that are already available in the String palette?
(2,693 Views)
