Vertical centered text
Hi all,
is there a possibility to define vertical centered text alignment for string
indicators?
Marko
(3,679 Views)
Yes, Select the text in the string indicator you wish to center, then look under "text settings", select "justify" then ""center".
(3,679 Views)
For vertical text, there's no simple setting. You can make the string indicator only as wide as a single character but you have to be careful about different fonts. Captions for controls and indicators can be stacked vertically - just show caption and then right click on the caption itself to select Vertical Arrangement. You could choose to hide the indicator itself and write your string values to the control's caption using a property node.
(3,679 Views)
If it does not have to be a string indicator, you can easily center the text either horizontally and/or vertically with a picture control. I have attached an example.
(3,679 Views)
