Vertical axis Solar tracker help
Hi all am new to labview, i have got my hardware working,its  a single axis solar tracker using two LDR in a bridge configuration which is the amplified using a difference amplifier and finally a lowpass filter..
 i am asking for advice on what blocks to use in labview to suite my hardware. pls any explanation will do
(2,379 Views)
yasmin,
You need to ask clear questions if you want good help.
What is LDR? Bridge circuits usually have four branches. Does each LDR have two branches or is something else used to complete the bridge?
What do you want LabVIEW to do? Does it monitor the output of the bridge? Does it control the tracker? Does it interact with human users? Does it save data to files? How fast do things need to happen? What should it do if an error occurs?
Lynn
(2,370 Views)
