Veristand Problem: When Configuring a project, searching for a library file as a dependent file.
The problem that I am having is that I took all of the necessary files in order to run a project and moved it to a different computer. When I open Veristand, and try to configure the project, a pop up window comes up with "Search for Dependent File: [filename]". It then says the missing file and the search directory. You can also browse for the file. So, for about the first couple of files, I just browsed for it and it was fine. But when it reaches a library file, I try to open it and it opens the library inside of Veristand. I think it thinks that I'm trying to get the file from inside of the library instead of the library itself.
Any thoughts greatly appreciated.
(2,962 Views)
This is the LabVIEW forum.
You'd be more likely to get help if you posted in the NI VeriStand forum.
(2,959 Views)
