Verify interval of 3 elements in while-loop
Hello community,
The LabVIEW-Code should compare a 1D Array in intervals of 3 elements with a constant. If all elements in the interval
is less than the constant "2", then the while loop should stop verification.
I would appreciate any kind of suggestion and contributions.
Message 1 of 8
(2,964 Views)
  • Why do you create a 2D array if you want to check a 1D array? I don't think you need the FOR loop at all.
  • Why do you compare that same 2D array with a 2D array containing a single element. The comparison should be with a scalar constant instead.
  • What is the meaning of "stop verification"? Stop the loop? Continue the loop but no longer check?
  • What is the meaning of the control labeled "s"?
  • What should happen if you run out of elements and no match has been made?
  • Your shift register and 2D boolean array makes no sense.
  • Why is the front panel and diagram maximized to the screen? Very annoying!
Message 2 of 8
(2,937 Views)
It is really not clear what you want, but here is some simple code that looks at the array and checks if there is a sequence of 3 elements that are all <2, and returns the first occurrence. While this is probably not the solution, it might give you some ideas....
Message 3 of 8
(2,925 Views)
Accepted by topic author MarcLee
@altenbach wrote:  I don't think you need the FOR loop at all.
Sure you do.
Message 4 of 8
(2,915 Views)
Thats exactly what I'm searching for! Thanky you very much.
Message 5 of 8
(2,911 Views)
Sure you do.
I was under the impression that his FOR loop was for data prep and that the checking would be happening in his while loop. So, yes, one of the two loops is not needed. Still, the code was so broken that it was hard to tell what the intention of the various elements really was. 😄
Message 6 of 8
(2,910 Views)
While Tim's code is simpler, my code is more flexible because I assumed that you'll ultimately receive data in the loop forever, one point at a time, then continue once the condition is met. Just change to a while loop and read your AI or whatever inside the loop.
Here's how that could look like. This loop will stop after three successive random numbers [0..10] are all <2.
Message 7 of 8
(2,905 Views)
@altenbach wrote:
Sure you do.
I knew what you were saying.  I was just trying to be a smart aleck.
Message 8 of 8
(2,904 Views)
