Varying the scaling of graph in runtime using numeric control or slide bar
 For my application i need to keep changing the range of both the X and the Y axis  during runtime.
Example i may want to change the range inaitially  0 to 5 to say 3 to 9 on the X axis.How  can i achieve this using a numeric controller or a slide controller.
please tell me how to incorporate this.
Thank you
(2,550 Views)
I suppose you already know about automatic axis scaling.
You can use a property node to change the axis min et max values as shown in the attached vi .
A double slider control was used here (right click on the slider and select add slider)
Message Edité par chilly charly le 09-14-2008 06:56 PM
Chilly Charly    (aka CC)
(2,543 Views)
Thank you very much!!! Help me a lot!!!Smiley Very Happy
(2,216 Views)
