Value Change Event
Hi
As you see the attachment I have a "Numerical Control" (X) and a "Numerical Indicator" (Z) whose value is changing by a "Numerical Control" (Y).
When I run the code and change "X" the Event Produce a notification but when I change the value of the indicator "Z" using "Y", the Event Structure does not produce any notification.
Why is that and How should I be notified when the value of "Z" changed?
Best Regards
V.S
(5,466 Views)
Hi VS,
an event is either fired by USER action (aka mouse clicks or key strokes) or by using user events.
Setting an indicator programmatically (by a wire ) will NOT produce an event. You can however fire an event using a "Value (signalling)" property node…
(5,464 Views)
Accepted by topic author V.S
Hello V.,
attached something that would work.
Depending on the nature of your application, there must be a better way to do what you need.
Normally when I tend to use this property node I start questionning my design.
(5,449 Views)
Hi Gerd W
when I use the "Value Signaling" it fires the event for every cycle of the while loop not only the first time I change the value.
Regards
(5,448 Views)
Hi VS,
yes, it does so.
When this is a problem for you you should only call that properety node when your value really changes…
(5,442 Views)
@V.S wrote:
Hi Gerd W
Regards
Then why don't you just use a Y:Value Changed event?
Based on this code, you should not have the timeout.  You should also make an event for the stop button being pressed.  There is no need for this loop to keep running when there is no GUI interaction happening.
(5,438 Views)
(5,432 Views)
