Valid type declarations within a formula node
What are the valid types allowed in a formula node. Specifically, can unsigned types be declared?
For example, assume you have hooked a control with type unsigned byte to the formula node labeled "x". For the output you connect an indicator with type unsigned word (16 bits). Inside you have the code:
/* formula node */
int16 y; /* defines output */
y = x;
/* end of formula code */
Let the input be 255. When the VI is run, the output will be 65535! This is because when the expression "y=x;" is executed, the byte value 255 is sign extended upon assignment to the int16 output "y".
Of course the assignment could be rewritten as:
y=x & 255;
so the output will be 255 as expect
ed.
The problem is that this is a little sloppy. It would be far superior if instead of defining "y" as "int16", it could be defined unsigned such as "uint16" (this doesn't work -- I tried).
The types you can declare inside a formula node (that I know of) are:
int8
int16
int32 (or int)
float32
float64 (or float)
The question is are there any other types available?
Thanks for your input
David Walker
(3,699 Views)
David,
The available types are
int8, uInt8, int16, uInt16 int32, uInt32,
float, float32, float64
Hope this helps.
Marcus Monroe
Application Engineer
(3,699 Views)
