VTEDS scaling error
LabView (and DAQmx) appear to give incorrect scaled values using VTEDS where the minimum physical value is not zero. Has anyone else encountered this problem?
We have demo VI's and VTEDS files that demonstrate the problem.
Thanks for any help.
Larry
(2,563 Views)
Are you using a minimum value that is below zero? If so, we have seen this before. We've seen incorrect scales when the limit is less than zero. This is supposed to be fixed in DAQ 7.4. Other than that there is no workaround.
-Sal
(2,539 Views)
