This widget could not be displayed.
VLC Player with 64-bit LabVIEW
Hi Everyone,
I had an application developed with 32-bit LabVIEW which was playing a video using VLC player. The application was controlling the video playback from LabVIEW.
As there was a need to build the same application with 64-bit LabVIEW I have found 64-bit supporting VLC player, which is running as a stand-alone application just fine. But when I try to access it with the corresponding DLL from LabVIEW (exactly the same way is in case of 32-bit), it throw an error 1097 on call library function node.
"LabVIEW: (Hex 0x449) An exception occurred within the external code called by a Call Library Function Node. The exception might have corrupted the LabVIEW memory. Save any work to a new location and restart LabVIEW."
Does anybody have an experience with controlling a video playback with VLC from LabVIEW, and specifically with 64-bit version?
Thanks in advance.
Arev
CTO | RAFA Solutions
(6,327 Views)
Accepted by topic author arevh
That error typically occurs with a parameter mismatch, as outlined in the KnowledgeBase below.
Error 1097 While Calling DLL with Correct Calling Convention
I think I recall that you may need to change the library call function parameters from Signed 32-bit Integer to Signed 64-bit Integer to make it work.
What operating system are you currently using?
Kevin S.
Technical Support Engineering
(6,280 Views)
Hi Kevin,
Thank you very much for the hint. It helped. I change data types to I64 and now it functions properly.
To answer your question I'm using 64-bit OS.
Arev
(6,269 Views)
May I know where to change data type to I64... Is in function return or ??
(4,161 Views)
Likely anywhere handles or pointers are used.
If you are having a similar problem, it would be good to include the definition of the function that is generating an error and how you have the call library node configured.
(4,125 Views)
