VISA write buffer
What data do we write in the write buffer?
If I only need to get information through serial ports, then, why should I write data in write buffer and then read?
I need to access data from the internet and through serial ports. How do I do using VISA?
Message 1 of 9
(7,010 Views)
If the instrument requires a command to take a reading, that is what you would write. It's all instrument specific. Some instruments just stream data and then you would not need a write. It all boils down to RTFM.
You can't use VISA as a web browser.
Message 2 of 9
(7,007 Views)
Okay
I need to monitor a system which is far away through internet. I know I have to use VISA, but what does VISA actually do? How do I get the information to my PC?
Message 3 of 9
(7,000 Views)
Is it on a local network? Then you can use VISA. Is it a web page? Then you can't use VISA.
VISA is an api that abstracts the low level physical connections such as serial, gpib, tcp/ip, etc.
Message 4 of 9
(6,987 Views)
It is on a local network.
If the write buffer contains commands to take reading, then when am I actually reading data from LAN ? Is it through VISA read?
Message 5 of 9
(6,981 Views)
Yes.
Message 6 of 9
(6,972 Views)
Okay thanks
Message 7 of 9
(6,960 Views)
hi
how i write (pwm)by visa labview
thanks
Message 8 of 9
(6,737 Views)
You've hijacked an unrelated thread with a question that makes no sense. Please start a new thread and really explain what you are asking.
Message 9 of 9
(6,728 Views)
